Strictly speaking, this is not a patch.
By waiting until the impromptu plugin to be port in the MM, here’s the way you can use the Orange-Line swing module.
This is basicely a master clock set-up with a swing function provided by the orange-line module.
Maybe I missed something, but I haven’t found any clock module available in the MM that provide a BPM CV output that O-L Swing needs to work properly.
!The knob you’ll use (and map to the MM) to control the clock rate is The Gain knob of RSCL!
There’s two additional output available for divide and/or multiplied clock (Both RGATE outputs). Main clock output is the tCLK jack from SWING.
The .vcvs format is not allowed here, but it’s meant to be just a module selection file for vcv you could load in an existing patch or to start a new one… in vcv of course. So I recommand you to load it from here as a vcv patch and save as a selecion.
Orange-line Master clock setup.vcv (1.3 KB)
Plugins involved:
-Orange Line
-Fundamental vcv
-Count modula
-Bogaudio
-4ms
Cheers… Can’t wait using Impromptu with MM ![]()
