I have no idea if it will even work, but I read with some concern that AI (again) will be creating output that may (read: may) infringe the IP of the companies involved. Thoughts?
Source? Link?
Even if it does exist, I donât think
a) Thereâs a audience or AKAI users whoâll be into it
b) It has nearly enough CV inputs to make sense anyway!
Not necessarily infringing on ip (if they release this under the GPL), but most certainly it infringes on trademarks (using meta + 4ms in the name).
Also definitely some vibecoded slop that nobody should trust to put on their machines.
Interesting⌠Kind of flattering (and mind-bending) to think someone would port the MetaModule to another platform. It appears to be non-commercial, so as far as I can tell it looks like the author is just posting something they made that they think is cool and sharing it with the world.
At first glance, the code looks compliant with the license, though I didnât look through all of whatâs there. What I did see was mostly just the headless simulator and the built-in brands copied over. I didnât see any plugin ability (the code itself is a plugin for the MPC).
Re-using the brand names is a problem. I was about to send the author a message, when I saw it already got flagged for using â4msâ:
The source repo was renamed from Meta4msXXL to Meta4MPCXXL:
There may be issues with artwork, too, I havenât dug in that far to see if it even uses artwork.
Depends on the licensing. Most of the modules in VCV rack are open source so providing the license criteria are met, then people are free to use the code. However, many developers limit that to the source only and have explicit licensing on graphics and panel layouts meaning they cannot be re-used. I have such a license in place and the only reason the Count Modula modules are available in MM is through a specific licensing agreement 4ms.
as a developer, I dislike this part of VCV licensingâŚ
to be clear I, 100%, believe a developer should be able to restrict distribution / re-use of their code/product - that is fine, but rather this âmechanismâ muddies the waters.
if you want to restrict this, just donât open source your code.
if feels like it was a loophole created, because devs were required to distribute the code due to derivative licensing, but then wanted a way to stop distributing the product.
feels like its against much of the spirit of open source - a way of gaming copyleft licensing.
(again, I donât have any issue with restricting distribution, protecting IP, I just donât like the lack of transparency of the way its done with VCV in particular)
Im not surprised, that some devs (esp if they are vibe coding!) are not aware of the nuances of this.
that said, I think with AI, this âloopholeâ wonât work - a vibe coder can just give the panel to AI and say, create me a variantâŚ
as for the port, yeah, itâs inevitableâŚ
seems everyone is vibe coding stuff now, so any open source project out there is considered âfair gameâ⌠and even non-open source (reverse engineering etc)
I think, weâll see a lot of âtransgressionsâ for licensing etc, likely not willfull, just ignorant , but hopefully most will âfixâ if they are notified.
Wouldnât it be ironic, if AI coding models are made to start respecting licences ![]()
anyways, hold on tight, we are going to see a lot of thisâŚ
but like a lot of âfree stuffâ, most will just be a novelty, that hits the headlines (wow, look what they did!), find little use, and fall into disuse in an unfinished state âŚ
github will need some more disks for storage of all this stuff ![]()
another side to this is we are starting to see, some vibe coders trying to sell this stuff, basically to pay for all the tokens they have spent, so licenses are going to be important!
my one hope⌠this doesnât set back open source, with devs deciding they donât want their code to be âripped offâ by AI/vibe coders.
esp. as these guys will just reverse engineer in this case, and itâll be real coders thatâll be adversely affected ![]()
the larger and much more concerning issue is going to be: not small companies having their ip âreplicatedâ but the big household firms having their ip âclonedâ, inevitably setting them on a path where many of them go bust, or are taken over by the hyperscalers (i.e. hugely reduced tax revenue for governments outside of USA and China). There will be a lot of this happening in the next few years unless governments change the existing laws to prevent this. Really frustrating as governments / tech experts have had 3 years to plan for these kinds of impacts.
I read a SciFi novel back in the day, where one aspect of the future world then was that China did state sponsored hacks of all new major software soon after its release, and offered them free on the net. It was to basically destroy the Westâs software market. I see this starting to happen with vibe coding reverse engineering everything. What will be the incentive to invest the energy and time making complex software, if someone will just reverse engineer it? This will keep happening unless someone finds a way to hide an âAI bombâ in their code that would kill the vibe coderâs system.
I think we need alternative ways of rewarding creative work in the age of AI. If any software can be copied freely, only AI companies will make money. If people quit making software that requires investment, progress will slow down (although IP also slows progress). But philosophically, I can go with it. Our ideas are not ours. We stand on the shoulders of billions. Creativity is a collective search process ![]()
