Can't split Polyphony gates?
I’m new to the MetaModule and loving it so far!
I’m trying to test a simple 2 voices setup, following the midi split method from the manual.
Works flawlessly in Rack, but in the MetaModule, the gates only seem to go through polyphony channel 1.
Is it something not implemented or am I doing something wrong?
Thanks in advance!
Yep, we just caught this bug! Update to firmware v2.0.10 and it should work. Sorry about that.
metamodule.info/downloads
Wonderful, thanks!
Can you point to me where in the manual shows you how to split midi? I dont see it at Using MIDI - MetaModule Manual<br>Firmware v2.1.6
Look at the “MIDI Mapping” section on this page: Using VCV Rack - MetaModule Manual<br>Firmware v2.1.6
