Hi, running into an issue building simulator and running it on this tag
It builds fine, no additional plugins added either. But running into this error:
cmake --build build
ninja: no work to do.
build/simulator
[Warn] (4236060.766, +-58906530) lv_init: Style sanity checks are enabled that uses more RAM (in lv_obj.c line #181)
SDL: 1 audio devices found
0: MacBook Pro Speakers (selected)
SDL: Audio device MacBook Pro Speakers opened at 48000Hz, 2 channels, 512 blocksize, 8 bytes per frame, 8120 format code
HostFileIO: foreach_dir_entry() in "."
HostFileIO: read ./EnvVCA.yml
HostFileIO: read ./QuadEnosc.yml
HostFileIO: read ./TapoSaveTest.yml
HostFileIO: read ./BraidsLFOs.yml
HostFileIO: read ./evenenv.yml
HostFileIO: read ./MappingRangeTest.yml
HostFileIO: read ./ChaosPlaits.yml
HostFileIO: read ./Djembe4verb_extgate.yml
HostFileIO: read ./EnsembleBasic.yml
HostFileIO: read ./FlipPan.yml
HostFileIO: read ./Orcas_Heart_Octo_Djembe.yml
HostFileIO: read ./EnOscPoly4.yml
HostFileIO: read ./Djembe4verb.yml
HostFileIO: read ./EnOsc_step_seq.yml
HostFileIO: read ./UntwistedBraid.yml
HostFileIO: read ./PlaygroundBefaco.yml
HostFileIO: read ./KarplusStereo.yml
HostFileIO: read ./SpringsintoCaves.yml
HostFileIO: read ./SlothDrone.yml
HostFileIO: read ./WanderVoices.yml
HostFileIO: read ./Braids-Quad.yml
HostFileIO: read ./DualEnvEnosc.yml
HostFileIO: read ./QuadDrum.yml
HostFileIO: read ./MIDI_Poly4.yml
HostFileIO: read ./Befaco4msPlayground.yml
HostFileIO: read ./EnOsc_8_step_seq.yml
RamDisk formatted and mounted
Raw image is 3610624, first byte is 2e
Ramdisk: 26292/29440 KB free/total
Loading ttf MuseoSansRounded-700 from disk path 4ms/fonts/MuseoSansRounded-700.ttf, 73816 bytes
Creating FONScontext
Loading ttf DejaVuSans from disk path rack-lib/fonts/DejaVuSans.ttf, 757076 bytes
FONS: Adding font DejaVuSans with handle 1
[1744146762 debug /Users/ericgao/Documents/Projects/ports/metamodule/firmware/vcv_ports/Befaco/src/noise-plethora/plugins/P_pwCluster.hpp:26 pwCluster] pwCluster initialised
[1744146762 debug /Users/ericgao/Documents/Projects/ports/metamodule/firmware/vcv_ports/Befaco/src/noise-plethora/plugins/P_pwCluster.hpp:30 ~pwCluster] pwCluster destroyed
Warning: SvgSwitch not configured with configParam or configSwitch
Widget graph_disp_idx 6 @ 83.000000 box size y invalid: inf. Fix=>0.000000 - @
Widget graph_disk_idx 6 @ 69.000000 box size x invalid: inf. Fix=>0.000000 - @
Widget graph_disp_idx 7 @ 208.500000 box size y invalid: inf. Fix=>0.000000 - @
Widget graph_disk_idx 7 @ 27.100000 box size x invalid: inf. Fix=>0.000000 - @
Widget graph_disp_idx 8 @ 268.500000 box size y invalid: inf. Fix=>0.000000 - @
Widget graph_disk_idx 8 @ 27.100000 box size x invalid: inf. Fix=>0.000000 - @
Widget graph_disp_idx 9 @ 329.000000 box size y invalid: inf. Fix=>0.000000 - @
Widget graph_disk_idx 9 @ 27.100000 box size x invalid: inf. Fix=>0.000000 - @
Widget graph_disp_idx 6 @ 66.750000 box size y invalid: inf. Fix=>379.424988 - @
Widget graph_disk_idx 6 @ 53.000000 box size x invalid: inf. Fix=>150.189056 - @
Widget graph_disp_idx 7 @ 163.000000 box size y invalid: inf. Fix=>379.424988 - @
Widget graph_disk_idx 7 @ 53.000000 box size x invalid: inf. Fix=>150.189056 - @
Widget graph_disp_idx 8 @ 163.000000 box size y invalid: inf. Fix=>379.424988 - @
Widget graph_disk_idx 8 @ 89.000000 box size x invalid: inf. Fix=>150.189056 - @
Widget graph_disp_idx 9 @ 163.000000 box size y invalid: inf. Fix=>379.424988 - @
Widget graph_disk_idx 9 @ 125.000000 box size x invalid: inf. Fix=>150.189056 - @
Starting LVGL
Registered vol 1 with path '/Users/ericgao/Documents/Projects/ports/metamodule/simulator/patches/'
Registered vol 3 with path '/Users/ericgao/Documents/Projects/ports/metamodule/simulator/../patches/default/'
Trying to load settings.yml from NorFlash
make: *** [run] Bus error: 10```
Debugger:
Process 22153 stopped
- thread #1, queue = ‘com.apple.main-thread’, stop reason = EXC_BAD_ACCESS (code=261, address=0xdac11410)
frame #0: 0x000000018dfdd94c libunwind.dylib_Unwind_GetIP + 224 libunwind.dylib_Unwind_GetIP:
→ 0x18dfdd94c <+224>: autib x16, x0
0x18dfdd950 <+228>: mov x17, x16
0x18dfdd954 <+232>: xpaci x17
0x18dfdd958 <+236>: cmp x16, x17
Target 0: (simulator) stopped.
Update 2:
I checked out 13.2 on /metamodule and it compiles and runs now.
