I have a few polyphonic patches and it’s easy for me to route my midi cc controllers as well as a separate keyboard through Ableton. I can also record chords and playback in Ableton, but the Metamodule never shows up for me as a MIDI device in Ableton’s devices, is this intended behavior?
sadly mm doesnt show up when plugging it into pcs. but ive been able to get mm to talk to ableton using 2x midi usb interfaces and 2x couplers
https://www.amazon.com/gp/aw/d/B07L8KFYBK
https://www.amazon.com/gp/aw/d/B08B1WR2CB
using all that you can also control mm with ios devices. or pc to ios, back and forth.
I’ve been using this device to connect to my computers that @offthesky discussed here: Working MIDI devices - #33 by offthesky
Hello! Based on this suggestion, I have connected
ableton (Mac)-> USB behringer crave → midi din thru → behringer neutron midi din input → USB neutron to metamodule.
Everything work, even with polyphony on metamodule!
Ableton can see only crave, but every channel go to the proper destination (ch. 1 neutron, ch. 2 crave, ch.3 metamodule).
Maybe the system can work with every synth equpied with both midi din and USB.
