I am new to all this and a bit unclear about the plugins. I downloaded all the plugins on the4ms site. Then loaded a patch from 4ms. I got a message saying some plugins not available. How do I know which ones and how do I get them? Thanks
you have to load the plugins from the settings on the mm. don’t forget to turn on autoload for the plugins you want to load every time you startup the mm.
i suggest reading this article as it has more good info: Using Plugins - MetaModule Manual
