Can I do this sample/drum machine setup? (repost from Muffwiggler)
so I’m thinking a patch with like 8 voxglitch wavebanks… (i’d buy the in/out expander so let’s get that out of the way).
that has each wavebank module targeting a separate sub folder per module with all my samples in them. so like folders “kick” "snare’ “perc” “noise” etc… so they aren’t all in the same folders. (IS THIS POSSIBLE with META? to have multiple folders on the card and then to target those folders with thismodule?)
then I just need a “sample in” module that can target whatever folder I want on the card… right? from there the rest is just using up CPU load and in/outs… can someone verify that you can setup that voxglitch “wavebank” module to read different folders on the card? that’s crucial to know.
then … now I have to find a sampler that can sample easily and lets me select a folder on the card to sample to so i can have my own sort of … file setup. then it’s just a trigger part input, dual line input for sample, a trigger in for sample record (I could 11 ins so far), and the 8 outs with maybe some mixing out of course.
? are it possible?
I tried voxglitch wavbank but it doesn’t load any sample… maybe a bug?
same issue here with the voxglitch wavebank, hope this can be addressed soon!
who would be the right person to ask?
eric, aka etcetc, helped port voxglitch over to mm
