When I map the metabuttons to Macro Oscillator 2’s Pitched and Percussive models, they work as expected and switch to the next selection in the array, but in the Resonator Module for Polyphony and Resonator type buttons, they don’t function the same. A little switch icon appears in the Meta Module and it only switches between 2 values rather than selecting the next item in the array (in this case only 3). It works fine in VCV Rack 2, just not in Meta Module. Is this a known bug? If not, I’d like to point it out in hopes that it can be fixed. Curious what makes the button behavior different between these 2 modules?
