Bog LVCO module causing noise, crashes
when switching between these 2 very basic patches (2 bog lvcos only, running out of 1/2), often i just get a squealy noise- and hear more noises as i navigate around the mm. instead we should be hearing different sine tones out of 1/2. and the mm will ultimately eventually screen freeze/no audio when i load one after the other (often by the 4th or 5th time loading from one to the other). not sure if relevant, but the mm is running 48/512 (latest 1.3.1firm and plugins)
test.yml (1.5 KB)
test2.yml (1.5 KB)
