Blippoo Box with MetaModule
Here’s the blippoo box patch we shared on social media this week!
What is the blippoo box? Benjolin? Rungler?
The late Rob Hordijk was a brilliant synth designer. His methodology of creating instruments was based on the idea of putting together a singular fixed patch with very musical modulation sources and allowing the user to navigate this terrain. One of his best designs, the Blippoo Box is emulated in this patch.
The benjolin oscillator is two triangle core oscillators whose frequencies are controlled by a circuit he calls the “rungler.” A rungler is simply a shift register with two triangle wave oscillators fed into it. The loop of the shift register can be locked to 8 steps or 16 steps. What makes this circuit unique is that rob added an attenverter for each oscillator with the rungler being fed into it - this creates a chaotic feedback network.
Chaos is different than true random; in a chaotic network, random signals can get locked in stasis where a pattern starts to arrive out of the randomness. Locking and unlocking the shift register helps create this stasis. The rungler signal in its own right becomes a pseudo melody & pattern machine.
The “Twin Peak Filter” concept Hordijk introduced in the Blippoo Box is two 18db per octave lowpass filters that are subtracted from one another. Subtracting two lowpass filters from one another creates a strange dual peak bandpass filter which creates all kinds of phasing and notching sounds. In many clones of the blippoo box or benjolin, these filters have a fixed spacing and are controlled by a single frequency knob. The original blippoo box did not operate in this fashion - it had dedicated filter cutoffs for each filter.
I like to use the XOR output of the benjolin to feed the twin peak filter. The XOR output creates logic gates derived from the two oscillators and are excellent for pinging resonant filters. The resonant filters now become pseudo-oscillators with a natural sounding decay, almost reminiscent of a resonant lowpass gate.
Long story short, twist all the knobs and make really psychotic bubbling textures!
External audio path:
-Main audio output on channel 1.
Internal audio path:
-Benjolin XOR output is routed to two parallel resonant lowpass filters
-Each lowpass filter is subtracted from one another to create the Hordijk “twin peak” filter
-The output of the filter mixer feeds into a brick wall limiter to smooth out the extreme dynamics of the patch
-The entire patch is then fed into a master spring reverb
-The rungler output of the Benjolin oscillator is controlling the cutoff frequency of both filters
MetaModule knob mappings:
A - Benjolin oscillator 1 frequency
B - Benjolin oscillator 2 frequency
C - Benjolin rungler 1 amount
D - Benjolin rungler 2 amount
E - Rungler pattern lock
F - Spring reverb dry/wet
U - Filter 1 cutoff
V - Filter 1 resonance
W - Filter 1 attenuverter
X - Filter 2 cutoff
Y - Filter 2 resonance
Z - Filter 2 attenuverter
Blippoo Box.vcv (2.4 KB)
Blippoo Box.yml (6.8 KB)
I am so thrilled to see this! I didn’t think it would be possible. Can’t wait to give it a go! Thank you!
What sample rate and buffer size are you running this on? I’m getting overflows immediately at 48000 and 128 block size, on firmware dev2.0 - 11
Ditto running 1.6.6, finally dropped down to 24k, 16 block size and retries set to 32, finally started to run then froze.
I’m in the middle of trying this out and I love it to bits. it
sounds amazing!
I had to remove 1 device at a time until I got down to just the Benjolin Osc. to get it to run here. Have updated to 1.6.6.
Darn, it froze my MM. Restarting doesn’t help because it loads the last preset, and freezes right away.
I finally was able to unlock the module by starting up without the card. That let me get into the settings.
At 24,000 and 256 I can run it.
Editing to say that removing the spring reverb frees up a lot of CPU- I can run it 48K, just barely.
It runs at 24k / 512
something like the following type of feature could be useful in cases where a patch needs to be run at specific rate/buffer settings:
enjoying the blippo box! still sounds great to me at 24/512
The patch files for this post have been updated with our new firmware, so that they will automatically load with the recommended sample rate and block size of 48khz/512. Enjoy!
