The Befaco Spring Reverb stops the patch due to load >99% even if it is the only module in the patch.
Also is this the right place for straight up bug reports? Of should these go right to Github?
-james
-james
So, this is an odd one, but that module only runs if the Block Size is 512. It’s the only module in all the built-in and plugins that has such a restriction.
I already know about this one, but in general it’s fine to report bugs here (and I’ll triage and make an issue on github).
If you want, you could post issues for built-in modules here:
or for plugin modules that are maintained by 4ms:
