Yet another wonderful free Befaco vcv module just released! Hopefully, a Meta port will happen soon as well! ![]()
Mate!
@hemmer Any info on whether Random8 will be able to be ported to Meta as well? Thanks! ![]()
This pair of recent modules and other stuff is why Iāve been a bit busy recently
Full transparency, the VCV versions (and day job!) take priority then fix up the metamodule version afterwards when there is time.
So Iroi first (not far now), then Random8. Not aware of technical limitations, though it does use hidden virtual knobs and custom RGB LEDs which might be a little fiddly.
Itās nice of you to ask/remind me,/show enthusiasm but also Iām always aware of metamodule and having conversations with befaco beforehand etc.
Thank you so much for letting us know! My apologies, as I definitely wasnāt trying to come off sounding like I was rushing anything.
I was just curious about which of the newer Befaco modules would make it onto the Meta, and itās always fascinating to see how VCV/Meta ports turn out, compared to their hardware counterparts (I have the Random8 on preorder as well, which I am definitely excited for).
Please take all the time you need, and thank you so much for all of your hard work! Its very much appreciated by the community! ![]()
No need to apologise, just clarifying the situation at my end. Enthusiasm is always welcome ![]()
Hereās my vote for Random8.
I just ordered the Meta buttons expander, and looking into which module ports would work well with it. Random8 is one that should greatly benefit, since it uses exactly 8 buttons as well. ![]()
Over on the Random8 modwiggler page, Mylar just mentioned: āI donāt think there are plans for a Meta Module version though to my knowledge Iām afraid.ā
He also mentioned there are talks about making the firmware open source as well, which should yield some interesting updates in the future!
Hmm, the Random8 code for VCV Rack is already there. I canāt imagine that the module runs much different code: Befaco/src/random8_core at v2 Ā· VCVRack/Befaco Ā· GitHub
(although I do wonder where this code came from, since the befaco github is still empty: GitHub - Befaco/Random8 Ā· GitHub )
Would so love to see this in MM.
The firmware was different enough/rpi specific that the VCV source for MM was developed side by side to be functionally equivalent. Thereās open PR to merge Iroi back to MM first, Iāll start work on top of that to add Metamodule (as a new PR). From conversations from Mylar I think heās happy for it to be added.
Thank you! Great news.
Hi @hemmer
FYI I tried IROI and found that when I turn full CCW the āmod speedā knob it seem to stays at full speed even if i turn back CCW (doesnāt respond anymore). I opened a thread
I was also wondering if thereās been any progress on bringing Random8 to the MetaModule since your post?
Thanks again for working on these!
I canāt reproduce, nor find the thread sorry! Are you sure this isnāt just the multiple knobs overlaid at same position thing (where youāre mapping to the wrong knob)? if you have a simple reproducible example let me know.
Just for me to understand: what is needed for a meta module version once there is a vcv adoption? In terms of work and who does it. Must such a version be developed by the original publisher?
In this case itās open source so itās technically no issue for someone to do that if they canāt wait. The work involved is: making the initial port, adapting certain things that donāt have direct MM mapping (e.g. some dynamic widgets) , fixing any crashes, debugging, making sure CPU usage is acceptable, checking behaviour is the same using simulator then real hardware, probably other stuff Iām forgetting! Some modules are really easy, others a bit more involved.
Youāre welcome to try the existing MM Random8 implementation that is being tested/discussed here: Add Befaco Random8 by hemmer Ā· Pull Request #621 Ā· 4ms/metamodule Ā· GitHub
For me itās hard because I donāt have a button expander, but Dan has very kindly sent one, so once I can test it properly we should be good to go.
Hi @hemmer
Been late to respond to your post.
Please find a video showing that behavior : https://drive.google.com/file/d/1MYdQlhT0TNfNVIQHWvElz_ptM0e1bMAX/view?usp=sharing
Iām on FW V2.3.1.
Thanks for your feedback!
Thanks for sharing, and lovely singing going on in that test btw! Itās a little hard to tell whatās going on to be honest, if you can share the patch (both MM and VCV) that would definitely help. One theory, there is an envelope follower modulation mode that you may be in which isnāt sounding active?
Also you could do what I just did (v.2.4.0, but no changes to Iroi since v2.3.1):
- new patch on MM, add Iroi
- map amount to A, speed to B
- vary both knobs and observe the effect on the LED between the two (should speed up/slow down)
Hi @hemmer
Thanks very much for you kind words, first time I share some vocals out of my bedroom hehe ![]()
So I made a video comparing VCV and META, hope this helps out : https://drive.google.com/file/d/10qLMX__h8rVYR3MWPjGKL05Y7wCikmkx/view?usp=sharing
Thanks again for your time on this!
