It was still on the old firmware but since it’s not mentioned in the change log I thought I’d still mention it.
Kickall does not react to gate 1/2 inputs, but reacts fine selecting the trig “manually” through selection.
I tested it with a vcv rack premade patch and by loading only the module on the meta module.
Thanks for the overall awesome work. Can you recreate this?
Mm I can’t reproduce here - I tried as you described (creating directly on MM), sending 10V gate (yellow) and it works fine (pink)?
DO other modules react to the Gate Ins as you expect?
