anDREW
September 10, 2025, 3:32pm
1
Are the basic VCV modules like ‘RANDOM’ availble in MetaModule as Plugins for creating a patch? Or is the only way to add the basic VCV modules is to edit in VCV Rack and send the patch over to MetaModule?
they are available as a plugin called ‘fundamental’. i recommend read this section on how to install/load (if you haven’t already): Using Plugins - MetaModule Manual
tip: set the plugin to autoload so you don’t have to every time you boot up the metamodule
once the fundamental ones are installed, any patch you make in vcv that uses the fundamental modules and transfer to mm will have those modules working
anDREW
September 10, 2025, 3:45pm
3
Awesome @offthesky that is where they were hiding, thanks for the response.
Maybe that plugin of ‘fundamental’ could be renamed ‘fundamental VCV’? It seems strange to me that it is not part of the builtin modules.
FYI, from the VCV Rack licence:
“The “VCV” name is trademarked and may not be used for unofficial products.”
Possibly something like “from VCV Rack” would be OK (IANAL), going by the module naming suggestion in the licence.
# VCV Rack licenses
VCV Rack Free **source code and binaries** are copyright © 2016-2023 VCV.
This program is free software: you can redistribute it and/or modify it under the terms of the [GNU General Public License](https://www.gnu.org/licenses/gpl-3.0.en.html) as published by the [Free Software Foundation](https://www.fsf.org/), either version 3 of the License, or (at your option) any later version.
In addition, you are granted the "VCV Rack Non-Commercial Plugin License Exception", allowed under section 7 of GPLv3, and a commercial licensing option.
>#### VCV Rack Non-Commercial Plugin License Exception
>A Plugin is defined as a software library intended to be linked and executed by this software.
>You are granted the permission to use this software's Application Programming Interface (API) in your Plugin in source and binary forms, as well as link to this software with the Plugin, regardless of the Plugin's license terms even if it would otherwise violate the terms of this software's GPLv3, provided that the Plugin is distributed free of charge.
>Derived works of this software may keep or omit this Exception.
This means that non-commercial plugins do not need to be licensed under the GPLv3 and can be released under any license of your choice (e.g. open-source or proprietary freeware). However, plugins that copy a significant portion of non-API source code from Rack must be licensed under GPLv3.
If you wish to release a proprietary commercial plugin, email support@vcvrack.com for commercial licensing. A commercial license is included for plugins sold on the [VCV Library](https://library.vcvrack.com/).
This file has been truncated. show original
anDREW
September 10, 2025, 7:05pm
5
Ah got it, “VCV” is the trademarked name so allowances must be made.
