Autobreak - Sample Loading shifted by one,
I am unsure about other sample loading mechanisms as I just starting diving into.
Using Autobreak and when trying to assign samples, if you select sample slot 1 it does nothing, Sample slot 2 when you load will place in sample slot 1, and so on. The last sample you can not load. Also curious if a auto-load first samples in folder would work with these plugins?
