Not sure if this is the right place or if it’s more of a Plugin but would be great to use the Meta as an audio recorder - similar to the 4ms wav recorder but maybe multitrack with vu and other goodies like compression and limiting ( v2.0? ) …
im seeing a “save FULL Sample” option in the extended options section of the SickoSampler module (requires dev 2.0 build). this module does have an audio recording feature but ive only tried sample playback so i can’t speak to how well the recording actually works. i think i read the dev set the limit to 1min @ 48khz. you can read more about it here:
we should hopefully see a decent compressor on mm (bidoo’s bar module) after etcetc is able to port it. read more here:
