Audio Reactive Oscillographics
This patch takes incoming audio and generates CV for use with a vector monitor to generate audio reactive visuals.
YouTube video of Audio Reactive Oscillographics
-Main audio outputs on channels 3 and 4
External CV Path:
-CV “X” output on channel 1
-CV “Y” output on channel 2
-CV “Z” output on channel 3
-Audio based envelope followers for audio left and right on channels 7 and 8
-Audio lfed into a 3 band EQ to filter out desired frequencies (left channel = bass, right channel = highs)
-The 3 band EQs are fed into an envelope follower, a VCA, and a SISM for level shifting
-Two additive oscillators are fed into thru zero VCAs and then to each X and Y output respectively. The Thru Zero amplitude allows for images to be modulated in all 4 vectors of the screen.
-The filtered audio is fed into a comparator.
-The comparator triggers a 5v envelope
Metamodule Knob Mappings:
A - Oscillator A frequency
B - Oscillator A partial count
C - Oscillator A Stride
D - Oscillator B thru zero VCA offset
E - Oscillator B partial count
F - Oscillator B frequency
X - “Z” attenuator
Y - High frequency audio envelope attenuator
Z - Low frequency audio envelope offset
Audio Reactive Oscillographics.vcv (3.8 KB)
Audio Reactive Oscillographics.yml (15.6 KB)
The files for this post have been updated to automatically select the recommended sample rate and block size of 32k/512. Enjoy! :smiley:
Sorry for being a total rookie , but can you please elaborate this patch a little bit more ?
I tried to connect some scopes on vcv but couldn’t get the results you have on the video..
Can you give me some more details about the issues you’re facing? With a video explanation maybe? This patch takes incoming audio into the sampler and generates visuals based off of it - the program material you’re using will have a drastic impact on the visuals produced.
