I would like to use the MM as calibration tool after updating my Seaside Proteus module.
I need calibrated voltages, how to do it with MM? thx
Procedure on Proteus:
Plug a 1 volt source into the TRANSPOSE jack. Press the NEW button once. You will now see two lights illuminated.
Plug a 2 volt source into the TRANSPOSE jack. Press the NEW button once. You will now see three lights illuminated.
Plug a 3 volt source into the TRANSPOSE jack. Press the NEW button once.
