8 plaits + orcasheart v2
I am using Tesseract sweet sixteen as a midi controller to tweak the timbre and morph parameters of each plaits. If you don´t use a midi controller you can try with multiples knob sets in MM, (actually this is something I try to avoid because is tedious, in fact too much knob sets makes MM collapse)
MM knobs are controlsling orcasheart main parameters.
Since I am a new user I`m not allowed to uploud the patch :frowning:
https://www.youtube.com/live/g7TKsXCZ2Ho
https://www.youtube.com/watch?v=cx1CUsqdcYM&t=1095s
that’s unfortunate. so even if you drag and drop the .vcv or .yml file directly here into the reply editing window, that also doesn’t work?
it´s amazing that it allows me upload this picture but not the .yml file
I found more options open up as you do more things on the site.
I pm’d you to do something else.
Could you try again, upload both the vcv and yml.
Please!
Yes. I’ll try it again . Thanks
8plaits02.yml (15.6 KB)
I used an individual output for each plaits
I built the patch inside MM. I don´t have the VCV file
8plaits.vcv (3.5 KB)
this is the patch version for VCV with an 8 channel mixer and a reverb that MM can´t run
enjoy!
