Hi!
Just a very simple question: How is the MetaModule with -5 to +5 modulation sources? Is it simple to configure or should one shoot for a full range modulation module?
Thanks!
Hi!
Thanks!
its fine… you’ll just get half the range (of ±10) - plenty for modulation, no configuration necessary.
also you could use a module (like A+B*C) to double the range if you needed it. (excl v/oct)
Right, simple enough – thank you!
