It seems that WAV Recorder was not in the list of modules in MM. Any chance of getting that in - since we have a microSD card.
i believe it was in the modwiggler mm thread, dan mentioned eventually adding a dedicated recorder on the main outputs. or perhaps there will also be a dedicated record module.
Actually he brought up the possibility of a multitrack recorder where you could select which outputs were sent to it. So you could record several stems.
My Wav Recorder isn’t going anywhere, I send my whole mix through it.
currently i just record via zoom h2n into an iphone (multitrack daw app)… but once the sampler capability is in the mm, having a built in recorder will be huge!
