4 Voice Poly Patch
Check out the video for this patch here
Internal Audio Routing:
-Two synth voices are created using a sawtooth wave VCO, a lowpass filter, and a Decay module
-The decay module goes into a VCA for “velocity”
-A rimshot and ROMpler kick module are mixed together with these voices using our Drum Bus mixer
Internal CV Routing:
-The polyphonic CV outputs from each sequencer are sent to each oscillator
-The gate outputs from each sequencer are sent to each decay module
-The envelope output of the decay module is sent to both filter cutoff CV inputs
-Outputs from each sequencer’s modulation outputs are fed back into the Algo X, Algo Y, shift, and Rotate parameters on Orca’s heart
Internal Logic Routing:
-The clock and reset outputs from the first sequencer are fed to the second sequencer and the drum sequencer to keep everything in sync
-Gate outputs from the drum sequencer trigger the Rimshot module
-4 Different kick gate patterns are sent to a sequential switch
-The Gate 2 output from Orca’s heart triggers a probabilistic gate
-The probabilistic gate steps the sequencer to pseudo-randomly choose 1 of the 4 kick sequences
External Audio Routing:
-Stereo out from Metamodule is ran into Mesa and then Leveling EQ Amplifier
-Leveling EQ amplifier goes into Listen IO for output
PolyJam.yml (39.5 KB)
PolyJam.vcv (5.1 KB)
