Ok. That’s it. I didn’t realize that saving it was possible through the program.
I’m not able to type directly in module’s text box. I have to write the file name in a text editor, copy it then paste into the text box. I’m on Windows. Are you able to type directly into the text box?
Thank you for the link. I’m stumbling my way through it but it is a good workflow and interface. The really useful info is sort of spread all over the place.
Might want to note that the save file creates one file extension vs vcv rack saves as a different file extension (if that’s the case, as I cant test right now)
There might be some confusion as to what file goes where in case they save the VCV Rack file with the same name as the MetaModule Patch?
