V2.08 preloading plugins not working
Preloading plugins dont work. Also system prefs audio settings reset to 48khz\64.
And saving a duplicate changing sound problem also persist.
The preload list and the audio settings are both stored in the same settings file in internal flash. I wonder if that got corrupted somehow? You can try a factory reset, though if you have any patches on the Internal drive you should duplicate to your SD Card or USB drive because they’ll be erased.
