Stellare Modular modules now available ~
Hmm.. I see what’s happening. The slug for the Stellare plugin with the Turing Machine in the VCV Rack plugin is “StellareModular” but the slug for it in the MM plugin is “StellareModular-TuringMachine”.
We’ll have to add the alias to the plugin and re-release it. But this firmware should fix it: https://github.com/4ms/metamodule/releases/download/firmware-v2.1.5-rc2/metamodule-firmware-v2.1.5-rc2-firmware.zip
Dan thanks for the quick response. But the firmware didn’t solve the problem. Meta Module still won’t load Turing Machine in a patch that has it, even though Turing Machine is loaded in Meta Module. I now see the naming difference between VCV Rack and Meta Module that you pointed out.
Also just found out that after updating with firmware v2.1.5-rc2-firmware.zip
I had another problem with Nano RANDOM module not being found in another patch even though it’s preloaded on Meta module. So I went back to previous firmware v2.1.4 and Nano RANDOM module loaded fine.
Oh, I forgot to also post the updated plugin that contains the fixed brand alias:
https://github.com/4ms/metamodule-plugin-examples/releases/download/StellareModular-TuringMachine-v2.0.1/StellareModular-TuringMachine-v2.0.1.mmplugin
And here is an updated firmware that fixes some more edge cases with auto-loading plugins:
https://github.com/4ms/metamodule/releases/download/firmware-v2.1.5-rc3/metamodule-firmware-v2.1.5-rc3-firmware-assets.zip
Thanks Dan! That fixed Stellar Modular Turing Machine. But Nano RANDOM module not being found in another patch I have even though it’s preloaded on Meta module with the updates.
The Nano issue is because of Nano vs. NANO in the filename. This plugin update fixes it:
https://github.com/4ms/metamodule-plugin-examples/releases/download/NANOModules-v2.0.9/NANOModules-v2.0.9.mmplugin
(all these fixes will be officially released on Monday)
Thanks for the fix Dan!
