Pre-load current is not working here for me
Afer scanning the drive, I loaded VostokInstruments and selected Pre-load current to the whole list but it didn’t pre-load as it should. I see “pre-load” is switched on in the VostokInstruments folder as well. What could be the cause of this? I feel like it’s always worked, though I haven’t used it for a couple months.
The current full Add-on library is larger than the memory of the Meta Module so it can’t load all of them. You may not be loading the entire library of course, but maybe the VostokInstruments is pushing what you do have preloaded over the memory level. You might try Auto-Loading the add-ons instead, only loading what is needed for the patch.
Thanks! I wasn’t aware of the auto loading feature. I’ll give that a try. Seems like a better way to work in general for me.
Yes, it is only inconvienent if you are loading big patches in a live situation, because it adds time to the patch loading.
seems like the best way to go is to not autoload anything but have MM auto load the modules you need on the fly off the disc, but that is not the way it’s working here for me. I’m probably missing something. I actually have to load VostokInstruments manually each time.
That is odd that it auto-loads other plugins but not that one. It should load any it finds on the SDcard.
