Possible bug in 12.2?
Just wanted to report in. I have a repeatable behavior here after updating to dev. 12.2.
If I try to send a VCV Rack file through WIFI module with my Launchkey plugged in to the USB port, it fails to send giving me the beachball and “Failed: No Response” As soon as I unplug the keyboard from the MM USB port, it works fine.
Also, on a couple occasions, the MM won’t initialize properly when I power it on and the screen remains white and it never loads.
FWIW,
Greg
I have had the white screen boot freeze a number of times since I started using the dev version.
ive also seen this a couple times. it always seems to boot up ok though after power cycle
Ok, this might be related to another issue with plugin loading taking a long time when a MIDI controller is attached. I’ve noticed a lot of USB traffic with some controllers on recent dev-12 versions but haven’t investigated yet. This traffic could cause wifi to timeout (and make USB drive or SD card access slow)
I’m not sure about the white screen on boot. Does it correlate to having a MIDI controller attached when powering on?
I don’t think it does. I can try and test it later or tomorrow if that would help.
No MIDI controller connected to mine.
