Issue with outputs dropping
Not quite sure if this is bug or not. I currently have both the meta module and the IO expander. At the moment, I’m trying to setup a series bogaudio Mix1 modules to go to each of the 16 outputs. I was under the impression you could send multiple patch outs to a single panel output, but every time I try to double up I lose the previous patch cable. Is this correct? If so, would I then need to create a sub mix per panel out as a work around?
You are correct, you’re not able to sum multiple module outs to a single physical out, you will need a sub-mix then out to a single panel out.
