Adding to this, Dan noted the other month on the topic " danngreen
The gate jacks can only see “high” or “low” while the audio jacks can see any voltage between -10V and +10V.
You can use the audio jacks for gates if you want. But you can’t use the gate jacks for audio (unless it happens to be square waves!)
