Apparently there are no inbuilt speakers so i connected the metamodule to my guitar amp. However it is barely audible and all i get is this insane buzz, can anyone help?
Connecting Eurorack levels to a guitar amp requires attenuating the signal, dropping it from hot modular level (10V+) to instrument level (<1V). You’ll need to use an output module, such as Doepfer A-119 or Befaco OUT, to convert the MetaModule output to high-impedance, low-level.
ive run my metamodule straight into a guitar amp without any hum or buzz. but i use a battery bank (they make ac ones) to power my eurorack rig, that eliminates just about any chance for ground loop noise issues. and i make sure the volume out of my mm outs into the amp are leveled down inside my patch. i recommend the ‘boost’ module in the 4ms producer pack plugin, with the gain turned down to 20-50% or so.
