Firmware v2.4.1 is now out!
New Features
- Clip indicators, by @gabrielroth. At the bottom of the screen, a red area flashes for each output jack that clips. Can be enabled/disabled in Preferences.
- Disconnect Cable button lets you pick which cable(s) to disconnect.
Improvements
- Parameter values in the manual control pop-up more closely match the value shown in VCV Rack (i.e. the output of
getDisplayValueString()is used for rack modules) - Cpu load tests measure first block time separately. You might see slightly different CPU load numbers in the Module Finder, which does not indicate anything changed on hardware – just the way the loads are calculated for the website.
Fixes
- Fix prefs tab USB Mode settings enabling/disabling with the wrong options
- Various fixes to disconnecting jacks (in some cases where a hub jack summed with a MIDI jack, they weren’t actually disconnected until patch reload).
- Misc GUI cleanup and fixes
Developer/SDK changes:
- Developer Mode now allows loading patch files via USB. Just copy a patch .yml file to the DEV_MM drive along with any plugins, and it’ll start playing automatically when you issue the install command.
- Developer Drive automatically connects to a computer on power-on if enabled (no unplug/replug required).
- Add filesystem directory support (opendir(), readdir(), rewinddir()) support for Ram Disk. This does not change the API (these calls were already in the API), it just makes them work.
stat()now returns the proper return value when used to query a directory. Again, no API change is needed.ModuleWidget::addChild()now works if called on awidget*that can be dynamically cast to aParamWidget*,PortWidget*,ModuleLightWidget*, orVCVTextDisplay*. Previously these widgets were added as graphic displays, now they are properly added a params, ports, lights, or text display.
