Distortion with Bogaudio VCO/VCF
Really bad distortion that isn’t there in the VCV Rack file.
PCB Version p11
Firmware version v2.0.0-dev-12.2
Bogaudio 2.0.0-dev-12.0
Distorted.vcv (3.2 KB)
Distorted.yml (12.5 KB)
Can anyone duplicate or confirm? @danngreen?
Yes I hear it. If I run the FM-Op output directly to a panel jack, then I don’t hear any of that noise, so it must be coming from the Mix8. Also, playing around with it a bit, I can get that type of noise to happen on channel 1 of the mixer (the VCO->VCF voice). So that also points to the problem being the Mix8.
Hi Dann:
Unfortunately, that does not seem to be the problem. I changed out the BogAudio Mix 8 for the NANO Performance mixer and am having the same issue.
Distorted 2.vcv (3.2 KB)
Distorted 2.yml (12.4 KB)
Hi @danngreen
I think I figured it out. It has something to do with the screen display. If the display shows the instruments, I hear the distortion. If I hit the white back button and go back to the “load patch/new patch/settings” screen, the distortion disappears. Try it and see if you can repeat it with the “Distorted 2” file I uploaded.
@danngreen
The display introduces a strange IM distortion into the signal. Very strange. It seems to increase with amplitude increase according to my tests. Also, when I exited the display by hitting the back button, the MM crashed and locked and played a single note. I have had that happen before. Hope that helps!
@danngreen
Went back to the original “Distorted” file. I can repeat the behavior there. The distortion seems to be worse on the first channel with the BogAudio VCO/VCF and increases with amplitude. It is greatly reduced when not showing the instrument display.
Interesting, yes when I go to the Main Menu then the distortion gets less. But it’s still there, I can clearly hear it if I isolate one channel.
I’ve re-done how displays work so they’re much more efficient now, and will be releasing that version shortly. But I still get that noise… Looking into it…
@danngreen Yeah, it is still there. For some reason, it is much worse with the BA VCO/VCF…not sure why. Could be the plugins or just the frequency range.
Yeah, this is strange. I need to test more to see if it happens with any other modules. It seems like changing a small thing makes it go away (even saving the patch from within MM, and then reloading it will make it go away).
I was playing around with the Plaits clone with BogAudio Mix 8 and got really bad noise and distortion…so, there may be a problem with the BA mixers after all.
Could be. I didn’t find a bug in the mixers, but I did find and report a memory leak in Bogaudio modules (technically all of them, but practically speaking it only effects ones with large memory buffers like CVD). Matt fixed it right away in the main Bogaudio repo, so that fix will be present in the MM version soon:
OK…good to hear. Looking forward to it!
Had some more problems with noise and distortion, this time with the Plaits clone. Isolated the problem to the Bogaudio MIX8. Substituted the Befaco mixer and the noise and distortion disappeared. Not sure why this is happening.
