Development firmware v2.0-dev
@danngreen More on the bug where the Adjust button doesn’t move a knob. I’'m using the dev-6 firmware.
I loaded up the very cool 4ms Drum Glitch Effect patch that your colleague posted here.
I connected the input and output and played a drum loop but didn’t hear anything, so I tried wiggling the knobs in the knob set. I found that wiggling physical knob F, which is mapped to the Address knob on the Switch 8-to-1 module, had no effect on the virtual knob. So I selected that virtual knob and tried to change it using the Adjust knob, but that had no effect either.
(Seems unlikely that this matters but: When I first loaded the Drum Glitch Effect patch, I didn’t have the Count Modula plugin loaded ((because of the preferences bug that’s preventing my plugins from autoloading)) so I got a warning that the Switch 8-to-1 was being omitted. I loaded the plugin and reloaded the patch, and then all the modules loaded fine.)
