Connect headphone out from Volca Keys to MM
When connecting the headphone out from my Volca Keys to the MM, what should I do to the signal to boost it to modular level? I used Bogaudio’s VCAmp and cranked it up to 12dB. Is that the correct way or are there better solutions?
for line level signals going into the mm, i recommend the airwindows bitshiftgain, it can go really hot. or perhaps the 4ms boost - stereo gain module (in the new producers pack) would work too? i haven’t tried that one yet tho
You can use our new Boost module from producer pack for this :smiley: it clamps at +/-5v so that you can drive signals into clipping territory if you want to.
If you don’t want clipping use Airwindows “PurestGain”
