It doesn’t seem to work for me. Is there an option somehow to use the CV inputs for gates or triggers?
They work for gates and triggers. Whatever module you have the CV jacks mapped to will see the signal you patch in – so if you patch a gate from 0V to +5V, then the module will see 0 to 5 on its input. How it handles that depends on the module. Try patching into a different module, e.g. map In 1 to the Befaco ADSR module’s Trigger In jack. Patch a gate/trigger signal in and you’ll see the LEDs on the ADSR flash.
Thank you! It’s working! I was using the Vostok Sigma module and couldn’t see the tiny lights and didn’t have audio evidence of it working so assumed. Sorry for the oversight! Thanks for straightening me out!
