Bogaudio FM-OP: Envelope is noisy
that’s good to note about fmop, i need to try out that setting!
also i noticed the clicks too on fmop, on the attack/release. that aren’t present in vcv. dan has stated elsewhere in this thread that they are going through the bog codes to fix things:
thats probably a lot of code! so we probably shouldn’t expect the bog fixes soon… regardless hopefully they can fix the fmop as well
